So, somewhere, somebody of some authority on one of the forums (here, or elsewhere, I can't recall), stated that with epoxy, a single layer of 6oz glass cloth would be sufficient to tab the floor to the hull - Darned if I can find it again, though. I PB'd the floor (covered w/ 1 layer of 6oz glass on the bottom, and 2 layers of 6oz glass on the top) to the stringers, bulkheads and along the floor bottom/edges where the floor meets the hull. Where the floor was seamed across the width of the boat (2 pieces of ply were needed for the floor), as well as where the floor sits on bulkheads and meets the original floor at the very front and rear edges, I put a piece of sealed 1/2" ply spanning between the stringers (sitting on top of bulkheads at those locations), to support those butt edges. I also cabosil-PB'd the 1/2" - 1" gap that remained between the side edges of the floor and the hull - I can't imagine that the floor is ever going to come out w/o cutting tools. So, going by the advice I can no longer seem to find a reference to, I tabbed the seams/edges with a single layer of 6" 6oz tape, and 3 coats of epoxy (one layer that I set it down in, one layer to fully saturate the tape, and one layer on top of that, after the saturation layer had gelled a bit.
Before I put the floor covering down, I just want a sanity check that this is sufficient. (Once the floor covering is down, I don't anticipate ever seeing the wood/glass floor again!
