compression gauge for pull starts??
Leastbay
What's a good one to buy? Anyone have a link to the compression testing for pull start motors?
Any thread-in style compression gauge. Just go to AutoZone and borrow one
F_R
No Title
Procedure is the same as with electric start. Don't make it complicated. Install gauge, crank motor till gauge doesn't go up any higher.
Hint: If you work on many motors, sooner or later you will find one where the cowling obstructs screwing in a hose-type gauge. This one takes care of that.
Hint #2: They all have some sort of a check valve to prevent the compressed air from escaping. Usually a tire-type valve. On a unit with a hose, make sure that valve is at the end that screws into the plug hole. If it is at the meter end, you will get false readings. Seriously false on small-bore engines. Harbor Freight is one example that has the valve on the wrong end on some of theirs.
bspeth
Thanks FR for the info on the tester mine has the release on the end of the hose. Couldn't get but 20psi on my evinrudes but they run great. Need a new gage.
