I have a mariah, V6 -mercruiser (1990) with a 3 blade aluminum prop. It is old and has been re-done serveral times. I think the prop serial # on the hub is: either 65-75120 or 45-75120-19. It has the splined shaft and regular hub (not the new type with the plastic shaft insert. My question is: does the serial # matter if I want to replace the 3 blade with a 4 blade?
