haulnazz15
- Mar 9, 2009
- 3,720
Re: Boat Show in CA - Glastron GLS 195 vs. GT205 vs. Four Winns H210
Sorry, but an EFI engine will not get 2X's better fuel efficiency over a carb'd engine. It's just two different ways of getting fuel into the engine, it doesn't change stoic values. Yes, there is better control over fuel distribution and atomization, but you won't likely see more than a 20% difference in fuel economy.
As stated above there is a big quality difference between a new glastron and a new four winns. A fuel injected engine will get almost 2 times better fuel economy over a carbed model. I'm not a fan of the new catylized engines either as each one runs about $1200 - $1500 to replace (no one knows how long they will last as it's new technology) and you have 2 per motor. A 2 or 3 year old boat without them would be much preferred but if you want new thats your choice. I would go with the Four Winns because of the fuel economy but most importantly the build quality. If you truly understand and can appreciate quality along with being able to afford it. There really isn't a choice. The frame of the boat, the electronics, the metals and plastics used are just of a higher grade and designed to last longer and be more trouble free. Also a tandem axle trailer is much gentler to the hull of the boat and handles better when going down the road.
