crankbait cowboy
- Mar 25, 2013
- 570
putting new deck down in starcraft, and got almost all info needed ( type wood,resin,rivuts or screws) from this forumn and thanks. wondering now what you guys think about following 2 options. in your opinion should i screw deck down and then apply the nautilux vinyl, or would i be better off to cut, dry fit plywood, apply vinyl and then screw to hull so my screws are accesisible in case of under deck repairs later. not sure wich is best way to go. a negative to vinyl first, then screw down would be seams at each piece of plywood, but as stated before a positive would be, being able to remove without tearing out vinyl. also wondering if 5200 on screws, or 4200 so they would be more likely to come out if needed. thanks in advance to any help you can all give me.
