fishthebay
- Aug 17, 2001
- 180
Hello everyone-<br /><br />I have a 1987 85HP FORCE outboard. Here are my problems that maybe someone can help me with.<br /><br />First, I keep my boat in the water for 2 week cycles. I run it probably 2 times per week and mostly on weekends.<br /><br />I noticed a few weeks ago that after I started the motor up and after it warmed up ready for me to pull out of the slip it wanted to die out unless I gave it a little more juice than usual.<br /><br />It kinda seemed like the idile was just a bit lower than usual.<br /><br />Once I was off it is fine and runs perfectly at all speeds.<br /><br />Any suggestions with this problem?<br /><br />Secondly, I have also noticed the last few times I have gone down to my boat to start it takes about 5 or so tries to finally kick over. This never happened before.<br /><br />The battery is new and fully charged. The starter is engaging fine and I pump the bulb up prior to starting.<br /><br />Once it starts its fine for the entire day and is fine on restarts.<br /><br />Also something that I noticed after I got is started today is that after it warmed up the bulb wasn't 100% completely hard. I pumped it up more as the motor was running and it didn't seem to have much affect.<br /><br />Again - once the motor is started it runs great, just seems like the idle is a little low and the starting process has been a bit slower than before.<br /><br />Thanks in advance for any tips on were to begin.<br /><br />I am no marine mechanic, but I suspect some type of fuel delivery problem for both problems the engine is causing me.<br /><br />Geeze - this force has been good to me for over 5 years.
