I JUST CAN'T SEEM TO GET A BREAK! I "WAS" going to pull off the port side exhaust manifold this afternoon and discovered that 3 of the 4 bolt heads are rusted away! As I see it, right now, the only way to get at the bolts would be to "pull the engine" and that's just not going to happen in my yard. It would be nice to have that capability but I don't. The only "good" thing, at the moment, is it appears to be flowing water alright. I'm going to put the "free flow" gaskets which will help a lot in letting water circulate on out thru the exhaust. I'm sure I can get to the elbow, in the bottom, to do as much cleaning as possible in the elbow area.
When the inevitable blockage comes, and I still own the boat, it may be possible to use a die grinder with carbide rasp and a mirror to grind off the heads. The bolt heads can't be seen from topside. I could then slide the manifold over about 3" and cut the bolt stubs off in order to lift it out. I don't want to do that risky job right now as long as the manifold doesn't have restricted water flow.
