swingline79
- Apr 19, 2015
- 8
Hello, I have a 1995 Johnson 25 hp model #J25REOR. I recently rebuilt the water pump, when I re-installed the lower unit, and after some fighting everything lined up fine and went back into place. When I started it, I had water coming out of the exhaust port, and exhaust coming out of the **** tube. I set it in a garbage can filled with water for this, and I also noticed air bubbles coming from the side of the lower unit where it meets the mid section. I'm guessing the water tube isn't set correctly. I'm about to pull the lower unit off again and check everything out. I was wondering if anyone might be able to tell me the right way to troubleshoot, and properly re***emble everything step by step? I've ordered the repair manual, but it'll be another 2 weeks before it gets here, and I can't wait that long. Any help or advice is greatly appreciated. Thank you!
