Re: 1994 60 degree 150 HP, only getting about 100-110 HP. cannot find the problem.
i also guessed in this direction, but sparkie says he has tried an alternative fuel supply with no result. a picture of the plugs would help to chek if this thing is running lean or not.
beyond that ,would en engine which struggles to get enough fuel at WOT run - like sparkie claims- perfectly smooth but just with a low power output? i doubt . i would expect missings, bogging, roughness etc.
I think you have a fuel supply issue from the boat to engine as a 115 would need less fuel than a 150. Try running it on a test tank with a 3/8 supply line.
