Re: 1994 60 degree 150 HP, only getting about 100-110 HP. cannot find the problem.
thanks flop, I will check the VST float, it appeared to be getting plenty of fuel from a visual inspection of the carbs at WOT, so I never did check the VST chamber, maybe something wrong there, but I will not get my hopes up. the motor drinks fuel like a sailor on shore leave.
I will also try pulling plug wires and running to see if there is a cylinder that is not contributing, although with good compression, good spark and good fuel, I dont see how.
I removed and cleaned and reinstalled all jets recently, made sure they were the correct jets, they are all tight, but I will double check.
This boat/motor combo is very common, I cannot see any way that could be the issue, the motor 2 years ago was on another boat, and I do not believe it had anything to do with the boat motor combo then either, just a weak motor.
It is odd to have 2 motors with the same weird problem. makes me just want to swear off these 60 degree motors. I have a late 80s 150 merc,and have friends who have the same motor, and man do those thing put out some HP, this motor does not hold a candle to them. although the 115 I had on it ran out great. I also have a friend with a 1996 150 60 degree on the back of a 18' bass boat, he tops out at about 60 MPH. his motor runs great, you can really feel the power when you throttle up.
I have had quite a few motors and boats come through my hands, I have never had this problem with any other motor, 90 degree OMC motors run out great so do mercs and yammys. these v-6 60 degree motors have really let me down.
