Re: 1989 Ski Brendella (boat restoration progress)
Hi everybody, I am the ******* who dropped this project on Hilton. If I would have had any idea this would be this big of a project, I would have never given him the boat. I guess no good deed ever goes unpunished!
I talk to Hilton just about every day and we discuss the progress quite often. I only wish I was there with him to move the project along. It really sucks to work on a project by yourself, but is actually enjoyable when you have help. I do have some questions and joined in on the discussion after Hilton asked me to. I am not trying to be difficult, I just really want to understand the reasoning behind the suggestions. I have never worked on fiberglass, so this is really a crash course in fiberglass repair for me.
As I understand the process, after the stringers are cut, Hilton is to soak the stringers in resin to get it to soak into the wood and cure. I assume this is to aid the soaked fiberglass matting with bonding to the now resin treated stringer wood. As a secondary product, the resin also helps protect the stringer from the moist environment that is going to be present in any boat. Please elaborate if I left anything out on the reason to soak the stringer in resin.
The next step I want to understand is the using adhesive to join a bond between the stringer and the original hull of the boat. I assume the process would be to rough the existing fiberglass and apply the adhesive between the stringer and the fiberglass base and allow curing time. How great is the bonding strength of the adhesive Hilton chose (sorry, I don't have the brand of adhesive handy, I am sure Hilton can chime in on this one) compared to that of fiberglass. Would the adhesive bond be better if the stringer was not soaked in resin prior to bonding the stringer to the fiberglass hull?
The last question, and really the reason I joined in this discussion, is the idea to remove all of the existing pocket. On one hand, it makes complete sense, and on the other it makes no sense at all to me. Does anyone here actually know how well the adhesive bonds to existing fiberglass? If the adhesive used will create a bond roughly equal to the new fiberglass bonding to the existing fiberglass base, then the existing pockets would actually be an advantage to keep, as to maintain as much original structure as possible. Also, I would think the new fiberglass bonding on the outside of the pocket would have better mechanical retention and less torsional stresses then if you remove the pocket and have to bond to the bottom of the boat. This is of course assuming that I am correct in that the function of a stringer is to strengthen front to back and not as much side to side in the boat.
On the other hand, if the adhesive is not nearly as strong (torsional strength, shear strength...ect) as the fiberglass to resin bond then I see absolutely no reason to even consider the use of any adhesive at all. Why not simply cut off all the existing channel, rough up the original fiberglass and build up the areas where the stringer does not contact the existing base fiberglass of the boat with a few extra layers of fiberglass to fill the gap? This would remove the weak link of the adhesive along the bottom of the stringer. Also, the removal of the pockets, at least in my mind, necessitates that the new fiberglass bond with the existing fiberglass is absolutely as strong as the original fiberglass to fiberglass bond was. I simply have no idea if this is possible.
Another question I have is how does everyone on here seal the areas where the bolts go into the stringer. The stringer isn't going to be exposed to moisture anywhere except where the holes are drilled through the fiberglass for the bolts. I believe that Hilton will attest to the areas rotted where in the areas of the bolts.
Last, I really believe we are actually splitting hairs over methods. Has anyone actually seen a stringer bond fail and come out of a boat? Somehow, I imagine it doesn't happen very often. In fact, I imagine there are many boats out there with rotten stringers that have no idea and perform perfectly fine. If Hilton would not have found the problem, he would probably have never had a problem with the rotten stringers sitting in there.
I am sorry for the long post, but I really do appreciate the help of those who respond to help both me and Hilton understand the mechanics of the stringer repair.
Galen
