numbersguy
- Sep 1, 2010
- 22
Okay I'm new to this forum but have been reading the posts for the last 2-3 weeks. I bought a 89 Johnson 40 HP VRO with a 20 ft pontoon attatched to it from a guy down the lake from my cottage. It ran for him and with the exception of some flooding issues at warm start-up, that sea foam seemed to help with, it was working decently. I plan to rebuild the carbs this winter as he was not into preventative maint.
Last week while cruising slowly the horn in the controls came on first with a few beeps then as a steady tone. I limped back to my dock and now after trying several things I'm turning to you all. The lake level is low and there are weeds, but I was careful to avoid them and I was getting water out of the tatle tale.
I bought a manual and did some reading and thought it was a VRO problem, but I get plenty of smoke at start up and the plugs seem to be oily when I pull them so I'm not sure that's true.
Now I'm thinking its a thermostat or sensor issue. I get plenty of water out of the tatle tale hose when it runs and when we limped in.
I didn't have all my tools with me so I have not done a compression test, but it was running before this. I plan to test compression this weekend.
Any thoughts? I'm tempted to just buy new thermostat and water pump kit and just replace them, but I really want to know what the problem is and fix that.
Thanks in advance.
numbersguy
Thanks in advance.
numbersguy
