My son brought this boat home and it was full of bad wood. I managed to gut the boat and have some questions.
1. Is the area below the transom that had the drains a seperate transom per say.?
If so is it wood or all fiberglass?
2. The lower part of the transom bracket started to push thru the fiberglass .What is the best way to fix this?
3. I cut to deep grinding down the fiberglass looking for the edges of wood and cut thru the boat.
4. When I cut the fiberglass around thevtransom I found some that never bonded. Do I just cut it back until I find a solid spot ?
