1985 B-liner stringers and deck rebuild
Mark42
Re: 1985 B-liner stringers and deck rebuild
Very nice work so far. Are you going to put a ski locker in there? I just ask because if not, you can get a very rigid floor by adding a few cross braces between the stringers about every 18" or 2'. (like the bulkhead you have, but it doesn't have to go down into the V of the hull, just straight across) Then if 1/2" ply is used, it will not flex. There is about a 2' span between the stringers, and a couple of cross braces go a long way towards firming things up.
BTW, that looks to be pressure treated. Are you going to use pressure treated for the deck too? Just curious. I would.
proshadetree
Great work so far.Mine was going to be done in a month or two.That was in august of last year.If it wasnt for the lawn,roof kids, wife, house,job It would have been done.Got to thank the wife for putting up with me and it for so long.Looks like quality work so far.
Bedrest2
Thanks for the comments. No ski locker, gas tank goes in there, 53 gallons.
Not PT its the 23/32 wood from Manards, It's the Arauco Ply, has the exterior
glue in it. Will use the same 23/32 for the floor all wrapped in glass.
Reading the forums about finishing with a rough finish, and ability to spray the
floor down with a wash out hose. (will be fishing out of this boat a lot)
Been keeping up you your top project Mark42, nice work, and I have to say
good help. Learned some things from your posts/project.
Bedrest2
Thanks for the comments/support. First time fiberglass repair. Did a floor in
my 16 starcraft once, oops twice once when my brother owned the boat b4 me.
Been reading on your rebuild also. Keep at it, wife and kids will enjoy it with you.
Mark42
The 23/32 will give a nice rigid deck. Don't know why the just don't make it 3/4 :D. I forgot about the gas tank being below deck.
What are your plans for making a wash down deck. Glass it all over water tight or use a vinyl decking, etc?
Bedrest2
Glass and then some kind of paint. Will be making the drainage ports better
than the pvc tubes I took out. Will even put ports to drain where Bayliner
did not. Should work.
Any thoughts on the PL adhesive to fill any voids.(pictured in previous post)
Bedrest2
Update!
Update!
Been working on the boat, not on the internet.
Got some pics to post, but have more work done without pics.
I'll get those later.
Got a lot of painting done pics to follow.
proshadetree
Looking good man.I had mine out for a test cruise.Going to look great.Need to get all these bayliners together and invade a lake somewhere.
Bedrest2
proshadetree, I try to invade Lake Huron (Saginaw bay) any chance I get.
Well I said I had pics on color so here they are. Remember this is a fishing boat.
Sides.
Back Board for rod holders.
Motor Cover
and the insides, remember fishing boat, no carpet, easy wash down.
I here Krylon Fusion sticks to fiberglass so I'm trying it.
NickAndJena
This is looking great. I'm in the middle of replacing my ribs and stringers (all but one), being able to take a look at someone else's similar project certainly helps.
I think I'm going to cut small channels or holes (about 1" in diameter) in the bottom/back side of the stringers near the ribs to allow water from topside to drain into the center of the boat. Are you considering doing any of that?
When I pulled out the old foam, we still had pools of water resting on the outboard sides of each stringer. I figure we need to allow this stuff to drain down into the bilge.
My camera battery died today, I'll have some pics of what I'm talking about soon but thought I might ask if you're planning on drain holes too.
Cheers,
Nick
NickAndJena
Uhh... Sorry man, it's been a long day. I suppose I could have read the rest of this thread before posting a comment/question from the portion of the thread on top. Looks like you're much further along than I am.
hehe -- Looks good though, good job.
Nick
Bedrest2
Thanks for the comment, NickAndJena
Yea I put half rounds in my stringers, fiberglassed then went back with a die
grinder and opened the holes after fiberglass was set up, tried to cut holes open while fiberglassing but took to much time and wasn't working well.
Fortunate to have tools to do almost anything.
Good luck with your project, been a real learning experience.ken
proshadetree
Looks like a pleasure craft to me.And If it brings you pleasure to fish then by all means fish.No kidding Id ride and ski in that all day long.Looking great.
Bedrest2
Completed!
Here are some pics of the finished fishing project.
This is what I did for some rod holders.
Here's looking forward.
And this is what I did for rear seats.
Thanks to all that help me figure things out.
Now if I could get Don S to answer me in the Volvo penta forum about my stumble I'll be all set.:D
chrishayes
Who needs Don S.? Pick your feet up when you walk and watch where your going!:p
Great job man, looks like you said screw it I dont need to wait around here for answers I think i will just do it and go fishing. Nice project!
Bedrest2
haha chrishayes I think you know what stumble I'm talking about.
Thanks for the comment! Fishing is starting to kick off around here so I had to
get er done.
Need to add my wash down pump yet but not necesary to go fishing, I'll
get that in at a latter date.
Good news is I have an interview Friday, time to restock the funds.:)
