Re: 1978 Mercury 80HP rebuild Spec ??
Ok Pro's. I need your opinion here!! I just cleaned the rods up and checked for flatness and out of roundness. They were all flat with in .0003
Here's the dimensions of the small ends. These were checked up and down (big end to small end) and then across!! (Spec is .957)
Rod #1 .9576 & .9578 = .0002
Rod #2 .9577 & .9577 = .0000
Rod #3 .9577 & .9577 = .0000
Rod #4 .9574 & .9574 = .0000
(Now Here's were I need your opinion)!!
These were checked up and down(Big end to small end), Across the two half's and diagonally.
Here's the dimensions of the Big ends. (Spec is 1.453)
Rod #1 1.4536, 1.4536, & 1.4537 =.0001
Rod #2 1.4532, 1.4531, & 1.4532 =.0001
Rod #3 1.4531, 1.4540, & 1.4534 =.0009
Rod #4 1.4535, 1.4538, & 1.4545 =.0010
I would assume I need to replace the bottom two rods?? Thank guys!!
