superharmonix
- Sep 5, 2010
- 140
Hello all. When I start my motor it is already at a very high idle. I can manually push the throttle arm back at engine and it idles back down properly. When I put in gear and then back to neutral, idle speed does not decrease accordingly. Instead, the idle speed barely backs down and when I am in neutral, the idle is WAY too high. The trunion screw is all the way screwed in as tight as it will go and it seems like if I had another inch and a half or so on that trunion I would be able to fix the problem. The bottom arm of the throttle control and the arm on top, connected by a spring, seem to move slightly independently of one another. It's as if when I back off the throttle the arm does not want to move back all the way. Short of driving around the lake with the cover off and manually readjusting wevery time I decide to shift into neutral, any ideas? Thanks a bunch, driving me nuts!
