My father recently died and left me his boat. I know it is probably not worth it, but I plan to rebuild/repair it. I know very little about boat repair and am looking for advice.
The first thing I noticed when I took a closer look at the boat was that there were plywood sheets on the bottom covering the deck. When I removed the plywood, I could tell the deck had to go- it was extremely soft. I have cut off the deck with a grinder and removed the plywood 'mulch' that remained. I removed the rotten benches and a live well that had holes in it. Pretty much all that remains is the shell of the boat. The transom is pretty solid, but it looks like the very bottom is beginning to rot. There are a few small machined holes in the sides and a couple small 'crunched' sections on the bottom. Otherwise, the bottom is solid too. I have tried to read as much as I can about boat repair and came across this forum. I need some help to lay out the next steps of my repair. I was thinking that it would be a good idea to start with the outside of the boat now while I still have access to both the inside and outside of the boat. Here is my overall plan:
1. Brace the boat by putting a couple 2x4's temporarily across the width of the boat and flip it over.
2. Grind out damaged sections.
3. Patch damaged sections. Looking for help/tips on what type of fiberglass to use for holes below water line and what thickeners to use for fairing. Should the holes be patched from outside or inside the boat (or both?)?
4. Sand boat bottom as smooth as possible, then add 2 layers of gel coat to finish outside first.
5. Flip the boat back over.
6. Add a layer of fiberglass to the inside (maybe biaxial 1708?). This would just be to reinforce.
7. Reinstall deck. I was thinking of using 1/2 inch plywood, coat it with resin on all sides, add a layer of chopped strand mat, attach it to the sides with strips of biaxial 1708 and then add a layer of biaxial 1708 to the top. Is this enough or should I add another layer on top?
8. Attach some wood to the sides and then reinstall the benches using fiberglass wrapped wood. I was thinking about using 2x10's wrapped in CSM and then coated with gelcoat. Will this work, are they too heavy?
9. Gelcoat inside of boat. Should I add something for grip?
I am sure I will have more questions as I get into things, but I need some help to come up with a good list of materials needed for this project first. I have checked out some online stores and here is what I came up with. I am looking for any advice/ suggestions you have to offer. Thanks in advance!
Biaxial Mat 1708 24 yds by 50"
CAB O SIL Adhesive Filler 5qt
CHOPPED STRAND MAT, 1.5 oz. 50", 20 YARDS
Gel Coat, White 4 Gallons
Epoxy Resin 4 gallon Kit............ = 3 gallons resin + 1 gallon hardener
Wood Flour 5 Quarts
The total is over 800 bucks (ouch!). Am I ordering way too much/ not enough materials?
Wood Flour 5 Quarts
