I did end up getting the port side rub rail removed by grinding the screws from the inside and popping them out, using the rail itself and a hammer to pry. Not the ideal, but it worked. I am going to think about the starboard side some more before I tear into that.
I was able to remove the engine well and therefore the rotted out transom. That is good/progress.
I also now have the boat indoors for the winter, so I was finally able to get the last of the water out. It will be nice not moving the thing in and out of the building to work on it all the time. Here's where it landed for the time being...
After getting the water out, I really started to look at the holes that I have in the hull from inside and out. Again, they are up towards the bow - close to a rib that runs port to starboard (they change in the bow of the boat. The front 25% bow area runs port to starboard, as shown the remaining 75% run bow to stern).
The area around the holes look like the surface of the moon. You can see where I am pointing are the holes. The worst of the pitting is directly around the holes, but the entire area is pretty pitted as well.
Side to side - these holes are in the center of the boat near the keel. I think if I were to rivet a patch there with MarineTex, I would run into issues with the other rivets in the area. Should I go straight MarineTex in these trouble spots and trust that the patches will be safe and leak proof? Is this hull too far gone to repair? These are the only holes I have found, but there are more pitted areas in the hull that I would want to treat before going the other direction with the resto. Thanks in advance.
Adam
