You can lead a horse to water !!!!
Thanks for your suggestions and your set-up obviously works just fine.
And for under $100 and proven safe. Less for an aftermarket pump.
Available at any OMC dealership.
Please don't use an electric pump !!!!
Thanks,, but I already have the electric pump, and will be putting it in... No reason not to,
yes the engine rpms did fall back to about 3k I think, it has been over a week now, since my first post..
Since my post I have checked the compression and found that all of the cylinders still have good compression 115-125 on all cylinders, I also placed a fuel pressure gauge on the fuel line just past the vro pump and have found that I have very little fuel pressure if any at idle or 2500-3000 rpm I had the motor out of the water on muffs and did not want to take the throttle to WOT. I had recently replaced the plugs, but I checked them again while I was checking the compression,they were fine and all were firing. At this point I am thinking about putting a new fuel pump on the motor I will be going with an electric marine pump made by holly.
Maybe I should do a youtube viedo of this, it seems like there is alot of intrest or questions. I have to see what I can do, should have the boat back in the water by this Saturday afternoon
Ken, they are law to have on a boat, now your just pokin at him!
But I get it!
I used gasoline to light my campfires only cause I have the room to run when I toss it and cause I know I'm doing it, very bad as an unexpected event to say the least.
I think if the pressure was kept to a minimum and the pump was wired to a relay that only runs while the motor is running things would be ok. I'd almost want to go one step further and run braided lines as a safety. I think running what you did is even less painful, no electric involved, as they say- keep it simple stupid.
Maybe I am missing something ??? however I don't think so.
What are you missing?
