My out drive started to slip then made a strange noise then stopped working. the electric shift does not go into forward but will go into reverse when idleing on the trailer. . The prop will turn when idleing or in reverse but wont turn with the engine off and the battery disconnected. I tried to drop the lower unit but it wont come loose on the rear... the front of the lower unit will move if I pry on it but the rear wont move any. I removed the torque/exhaust fin and water strainer but I cant find any other bolts to take out... So what am I missing?
Thanks.
Update:
For future searchers...
To remove the lower you have to disconnect the shift wires behind the engine.
With the drive tilted up pull the shift wires through the gimble housing.
Tilt the drive down then unbolt the five bolts on the top of the drive. Be careful the lower unit will fall off if you aren't supporting it.
Now with the lower portion unbolted from the cap. Lower it enough to pull the shift wires through the upper unit.
That's it...
Now take this to a workbench and remove the six bolts by the cavitation fins.
remove the water pickup strainer screw.
remove the exhaust fin and the plate under the fin that the water pump pick up hose is attached too. Just pull the plate away from the housing.
Then you can see the seventh bolt above the water pickup tube. I removed the tube to get to this bolt.
Now the lower will come off the intermediate piece.
Very easy. No need to mess with the pivot caps and seals or mark ball gears!
Edit / Delete Edit Post
Thanks.
Update:
That's it...
