Re: Temperature Alarm Sender
The only temp. sensor I can see in front is on the thermostat housing. The other two sensors I have are for oil pressure switch and oil gauge. Any chance the thermostat sensor is dual station on 2000 4.3 PEFS?
Frustated - Alan
If you mean can the one sensor do both, no. One is a simple on/off switch, the gauge sender is a variable resistor.
The alarm switch is on the front of every engine I have ever seen that had a temp alarm. Maybe on the manifold runner next to the thermostat housing, who knows. You're just going to have to keep looking. Maybe a previous owner took it off and cut the wire off.
