Re: 1985 force 125 carb mixture screws
Hi John,
Ok,gotcha on that
We had talked before,but the thread went dead i guess.lol
Im the newbee from minnesota that couldn't WOT.
Remember?
85 bayliner with a 85 hp force.
To recap:
Goes fine until 1/2 way through throttle,and cuts out.
Then I run it slower for 1-2 minutes,and WOT,and it takes off for about 5 secs,and boggs down.
Since we have talked,I got a plug tester,and seems like plenty of spark.
Also tried the bulb thing,a different tank,took off the filter to the gas and checked it,and went further and checked the diaphram,and got a new prop.
Seemed like when i had someone in the front,it went a tad longer at WOT.
I pulled it up in the drive way today as we had 60 mph winds down on the dock,and i live on the lake next to the loading ramp.Glad I did..lol
Wasn't expecting the wind as bad as it was today.And it's been a windy year.
So was just going through the things I could.
Will have to get a timming light some time and check that too.
But it seemed to have wet and a tad oily plugs,but I guess that can be normal.
It will once in awhile die inbetween shifting lately,so I do need to take it out,and set a higher idle.
I did take off the manifold today,and cleaned out the black insulation off of the inside,as it needed it.
Also took the black hose off of where it comes from the motor,and goes to the manifold.
Could not blow through it,but mabe the motor has to be running for it to suck air hu?
Later I took it off of both ends and blew,and insulation(black stuff) came out the other end.
Cleaned out the hose,and took off the little pet **** or attachment to the moror as well.
So should be good to go,but still thinking it has to be running to move air through that.
So should be all cleaned good to go there.
Sure is a little pin hole to that petcock,or attachment.
Ran wd40 through it,and cleared that as well.
Boy I can see that any little obstacke could clog that easily.
Do you know if that being clogged would matter alot?Heck it must of been clogged a long time by my thoughts,just because of such a small air opening,but who knows.
Get back to me when you can.
Thanks
Scotty
