coolguy147
- Jul 14, 2008
- 2,817
it's an aluminum boat in great condition. it currently has a short shaft transom though. i want to make it a long shaft transom and that would mean me welding some aluminum to increase length. then rebuilding and adding reinforcement and such splashwell etc.
it has a 50hp motor that seems a bit slow. 1961 merc500. and it's starting to run it's age. put quite the hours on this puppy.
i want to put a 3 cylinder evinrude johnson 70hp on it.
the boat is currently rated for 45hp.
i believe the hull is well built and it's all riveted aluminum. no wood except for the transom. it handles well in rough but it is bumpy.
strong bow.
pic are on my signature. photobucket etc.
i won't be doing this for a while and thought i'd get some ideas as i do like to dream.
http://s659.photobucket.com/albums/uu316/sgdteam/#!cpZZ1QQtppZZ24
as you can see in this picture i would like to weld some aluminum to make it a long shaft
so i'm basically looking at about 230-260 depending on whether i get PT&T or not. i think i'm ok on the weight.
what do you think for a light weight aluminum boat top speed with a 70hp?
strong bow.
