Riverrat8428
- Feb 4, 2008
- 37
Motor began missing last week and than would not take extra throttle above 3000 rpm
Tried to pump fuel bulb but did not help
The engine has been trouble free until this began. Here's what I have changed so far.
Upon inspection of the fuel tank, i saw some brown sticky crude that looks bad. So we began to clean things up.. New fuel line, new fuel seperator and a filter change in the clear fuel bowl. No change still will not go WO..
Eliminated the fuel tank by running on a differant tank with no contamination, new spark plugs.... same problem.
removed the bottom cowling and changed the high speed filter screen and 0 rings and cleaned the clear water seperator on the engine... Still the engine willl not go any faster than 3000rpm
Note: the clear fuel bowl is always less than 1/2 full is that normal and please help...Bill
