1982 2 stroke 40hp mercury flywheeel adjustment problem
Status
Not open for further replies.
grizzly83
I recently had a problem on my mercury that required me to remove the flywheel for repair and in my hurry to repair the motor I forgot to mark the flywheel for reinstallation. How do i know that i have reinstalled the flywheel correctly? there are no witness marks on the crankshaft itself to line up with the tdc mark on the flywheel so I am not sure what to do here.
jaykibo
Re: 1982 2 stroke 40hp mercury flywheeel adjustment problem
Hi grizzly, did you get a solution to your problem? I have the same issue with my Mercury/Mariner 50hp 1983. I pulled the flywheel off and didnt mark it.
Yes, I know. Rookie mistake. Oops. Anyone know how to put it back on properly?
Thanks in advance.
sunburnt
has 1 key way cant go on any other way! to check tdc when installed will con frim this. bring #1 piston to top of cyl -check with a dail , screw driver, pencil etc.. then should be 0 on fly. if fly was totaly disassembled you may have to reinstall correctly.
jaykibo
Thanks sunburnt. Ill do this tonight.
To add, I also removed the stator and trigger assembly. Is there any special way of putting these back in too? Thanks
bktheking
Are you the gent who removed the 8 bolts out of the top of the flywheel?
jaykibo
Yes, I did. Although I can imagine I wouldnt be the only gent who did this.
My engine spat a rod the other week so I had to do a complete top end rebuild.
poolshark930
I did this too. So at tdc on the timing mark should be on zero? Or I read another thread that said 4°. And how do I find top dead center??
The Force power
Welcome to IBoats,
When you have a question; click on "new post" and ask away. when you ask in someone else's post it's called "hacking"
(besides this is a very old post)
On the top of the form you'll find yellow sticky-notes that are helpful, please read those before posting.
Now to your question;
insert a screwdriver into #1 spark plug hole and turn the flywheel till the screwdriver is sticking out the most.
This is your top dead center ( TDC )
TDC is NOT your timing mark
GA_Boater
Please start a new thread of your own. This one has been dead for over 8 years.
Closed.
Status
