Re: Replacing engine, need advice on using auto block
I installed a water pump from a 1985 Chevy Caprice about 3 years ago. It is working fine. Our boat gets regular salt and fresh water use.
My understanding is the freeze plugs need to be brass and you need to replace the head gaskets. My understanding is also, that if you are doing only fresh water, that the headgaskets would be fine. The cam is differant in a truck than a boat, but a truck cam will work if in a pinch. I would swap the cam out of your old engine if you can though. Being a 99, its probably a Vortec engine and a one peice rear main seal.
There are some small differances here and there, but the main differance in the Vortec over a non Vortec is the heads, intake, etc. Make sure your intake matches whatever engine you buy. The rest should work fine.
You have to use your carb, dizzy, starter, etc etc. Basically anything fuel related or electric related must be marine only or you risk explosion from fuel fumes building up in the engine bay.
I may have missed some things, but I think that is all you need to know, from what I remember replacing my engine earlier this year.
