Palssonater
- Jul 3, 2007
- 60
'01 Johnson 90HP V4. Turns out my cracked gearcase was severely distorted. Needed to order a new case all together. Putting everything back together now and wondering what dictates how much to shim the driveshaft. Shaft is spinning freely to prop but you can still hear the clicking of the gear. Is there a gear lash level that I should have at the prop. Running about 20 to 25 degrees now.
Any specs or procedures out of any manual would be very helpful. As well as any words of wisdom when dealing with shimming your driveshaft and reassembly of bottom end?
