Ok so first off this is my first post in the forum. Seems like a nice place with helpful people.
So I just bought a 1989 Grady White 22 Seafarer and it has a evinrude 200hp vro motor on it. Upon first getting it many people told me that I should disable the VRO and run premix. I feel that this would be hard to do with a 90 gallon gas tank, am I right? Also the thing sat for 4 years so I'm expecting to do some maintenance. We did get the motor to start pretty easily actually and it seemed to be running pretty strong on all 6. What things should I look for as far as maintenance on a motor that sat for an extended period of time? Also what is the proper sequence to start the motor as there is a primer bulb and it has the primer solenoid at the key that I can activate. I do plan on getting a four stroke motor in the next year or two but if I can put off that cost for a little and get some use out of this motor if its not going to be a huge hassle then I'd like to do that.
Hopefully someone can steer me in the right direction.
Thanks in advance.
Mike
Thanks in advance.
Mike
