jaxnjil
- Aug 3, 2007
- 1,368
i am at the marina and get a wi-fi signal. it is only one of 5 bars though.
as a result when on line it drops and then picks up again.
wen not on line every so often get a message there is a wire less connection. do i want to connect -pop up.
my question is- is there any kind of antenna or trick i can use to get a better signal? it helps when i get to the bow and under the hatch but cant go any farther that way.
