This is the Fish Intercept Vehicle I, a 1988 14' Western that I prototyped last year and then rebuilt this year. I finished it last Friday and sold it today. The pic's don't show the Minn Kota Terrova 55AP/CP that I sold with the boat. I bolted it on and bolted down the seats per the buyers personal liking. Yahoo! Now I can buy my Trim and Troll system for my 18' Tinny, (FIV II)
I inherited the boat and priced it at 2500.00. I sold it today for 4500.00. I doubt that I acutally made any money but I think I got most of it back.
I stripped the boat clean in December and then put it away until two weeks ago. It only took two weekends to get it done. There's a secret I'll tell you about doing this type of retrofit. You don't over design for one, just lay down two 1x1/2 by 1x1/2 by 1/8 aluminum angle for stringers then the deck and build on top the deck using thin (.020) aluminum angle for your tie in's. The deck is 1/2" shop grade ply sealed with GluvIt the sides are 1/4" shop grade ply. below the deck are pool noodles that are cut in half lengthwise and laid in. The center of the deck only has a span of 15" between the stringers so there is no flex whatsoever. Two guy's can lift the boat off the trailer with the motors on it. It's light! I sold it before I had a chance to even put it in the water but it would do 25 before and it was at least twice as as heavy.
By the way, see the transom in the last pic. That's why you should never use HTS2000 to repair .065 aluminum. It didn't hurt it but it warped the heck out of it taking it all the way up to 732 degrees. I should have known better. It doesn't show that bad, the camera flash highlights it and makes it look worse than it is.
