  #1
Old July 15th, 2008, 06:16 PM
fishinhardwater's Avatar
fishinhardwater fishinhardwater is offline
Default 1988 Mariner 60 HP Overheat alarm
My 1988 mariner 3 cylinder 60 HP engine's overheat alarm goes off on the throttle control box. This beeping occurs at Wide Open Throttle only. The dealer sugggested new impeller, did that, problem still occurs at WOT. Tell tale is strong at all speeds. When i drop the throttle back to slow or neutral beeping stops, and engine stays cool entire time even when its beeping. By the way its a continuious beeeeep, not a beep beep beep, which would be for low oil. I can also run engine at 1/2 and 3/4 throttle all day and beep does not occur. thank you
  #2
Old July 15th, 2008, 07:42 PM
Laddies Laddies is offline
Default Re: 1988 Mariner 60 HP Overheat alarm
I believe you engine has one of the small senders right next to the top spark plug and if it does they are prone to causing that type of problem.
  #3
Old July 15th, 2008, 09:28 PM
Thank you Laddies, my motor does have this wire. its a tan wire about 4" long. i guess its worth a shot to replace it, what do you think?
  #4
Old July 16th, 2008, 03:17 PM
marty53 marty53 is offline
yea.. that bad boy is like $40-50 bucks. its either that or you could have a stuck poppet valve. those are cheap.
  #5
Old July 16th, 2008, 05:37 PM
just bought the temperature sensor/sender?? 90 bucks.. had to order it. the one that Laddies said.(right next to top spark plug) hopefully it will be in by friday. parts counter guy said also might be sand/dirt inside water pump.. i guess ill do it one piece at a time. (hopefully i can fix the problem myself in less money then it would cost to pay someone to fix it) Both of your inputs are much appreciated! thank you.
__________________
fishinhardwater
  #6
Old July 18th, 2008, 11:35 PM
Got the new switch assembly, its much more sensitive then the old one. alarm goes on at full throttle but stays on longer as i back down on the throttle. Went home shoved a garden hose in the coolant lines blew out all the lines i could without dropping the lower unit. then i went back out and the alarm sounded 4 times at full throttle.. then all of a sudden it didnt sound anymore. i drove around for 20 minutes full throttle and never heard it again! I think clearing the coolant lines with the garden hose may have solved my problem? or maybe just pushed it down the line for trouble later? but i hope i solved it for good. thanks the piece i bought is number 3 on this chart. http://www.crowleymarine.com/mercury_parts/1991/250.cfm
__________________
fishinhardwater
  #7
Old July 24th, 2008, 01:13 AM
update:
alarm is coming back on again! i cant figure this out. IS THERE any way possible that i am getting this alarm because of AIR in a fuel line? or maybe i should mix oil RICHER then 50:1 ?? any suggestions?
__________________
fishinhardwater
  #8
Old July 24th, 2008, 09:37 AM
Have you disconnected the auto blend sender and ran the engine to make sure that its not causing the horn. Your engine does not have a thermostat or popit so that can't be the problem. When you changed the impeller was the old one all in one piece or could there be pieces loose in the cooling system, were the pump base gaskets in good shape sometimes they will allow exhaust into the cooling system.
  #9
Old July 25th, 2008, 12:25 AM
yes sir, autoblend is disconnected and i mix 50:1. (do u think i should try to mix richer?) when i changed the impeller, the old one looked good and all in one piece. however, i did not change the whole water pump kit, just the impeller, maybe i gotta do the whole thing... another quick question: after i "flushed" the cooling lines with the garden hose it finally ran WOT without beeping so maybe i just pushed the problem down the line further until it got stuck in something again? thank you for your help, Laddies, its much appreciated.
__________________
fishinhardwater
  #10
Old July 25th, 2008, 09:54 AM
No the 50 to 1 oil mix is not the problem, I have been checking parts bulletins and they say not to use a 96829A1 switch as a replacement use 12415 the early number was a 260 degree switch and cost $85 and the replacement is a 285 degree switch and is less than $20 but you have to buy a wire thats $30 or just make one up heres a link http://www.mercruiserparts.com/Show_...Cylinder+Block Item 38. Both Bam marine and US Boat supply have the new number listed in their parts books, did the place you bought yours cross the part to a new number or just ship the 96829 to you? That could be the problem I suppose. If you engine is a salt water engine removing the exhaust cover to check for debris could be a problem.
  #11
Old July 25th, 2008, 11:18 AM
#38 measures water temperature. i got that sensor once, and thought i had the wrong one. then i went back to the dealer and brought the 96829A1 with me and they ordered it for me. if i go back and buy the 12415, do i unhook the 96829A1 wire and put the 12415 wire back on instead? or leave both on?
__________________
fishinhardwater
  #12
Old July 25th, 2008, 12:17 PM
I don't have the serial number of your engine but if you use it on the Bam web site you need the sender the parts manual lists for your engine.
  #13
Old July 25th, 2008, 12:18 PM
My Serial ob248347 1988 Mariner 60 hp 3 cylinder.
Heres what i have learned
Part # 12415 is for water temperature.
Part # 96829A1 is for metal temperature. (which is set to 260 degrees)
Now theres another part listed #96829a2 (which is the same as 96829a1, but its heat is set to 285 degrees) but my serial numbers not listed under that one. number 14 on here- http://www.mercruiserparts.com/Show_pictures3.asp?dnbr=%2016404&ivar=IMAGES/COMMON/19261.png&inbr=336&bnbr=100&bdesc=Exhaust+and+Mani fold+Covers
>Was wondering if i put #12415's wire on the same place where 96829a1's wire goes?
>and do i disconnect 96829a1 completely and only have #12415 as my temperature sensor, or do i put both sensors on?
Thank You
__________________
fishinhardwater
  #14
Old September 12th, 2008, 10:01 AM
ok, heres what i did. its probabaly not right, but i took off the very last hose that goes to the tell tale and put a fatter hose on there with out the small hole to pee out. running like this, there is no more overheat alarm. maybe the water wasnt going thru fast enough and was getting too hot? i dont know but it works now
__________________
fishinhardwater
  #15
Old March 24th, 2009, 12:58 PM
rhurt rhurt is offline
Wow.... Reading this thread was like De Ja Vue (spelling)... This is exactly the same thing my '88, 60 Mariner is doing. Only at full throttle and only after you are just up to speed and enjoying the ride..... I usually cut back to 3/4 and it will go off, but sometimes it takes a few minutes. The stream of water looks weaker and it has always been very slow to pump right after starting the motor. So, I too am planning to change the water impeller and possibly the entire pump. But I think I may also look into this sensor wire described and I will definitely look at increasing the size of the P tube!!!!
How have things worked out for you and what do you feel like the real issue was?
Thanks for such a great thread and real socratic discussion of the issue, good stuff!
  #16
Old March 24th, 2009, 01:18 PM
DuckOfDeath DuckOfDeath is offline
I had the same symptoms a year or more ago. Removed the water jacket cover to clean off the scale buildup and discovered my telltale hose was partly obstructed. The telltale stream looked good beforehand so I never suspected an obstruction there. I tried to convince myself that it could have been the scale buildup causing the alarm to justify all the time I put into cleaning it up. Truth is it was likely the simple 3 minute fix of clearing the telltale hose that really solved it. This was after 2 water pump installs and troubleshooting the sensor too. Doh!
  #17
Old March 25th, 2009, 02:36 PM
after installing the fatter hose at the telltale, it has never overheated, and the alarm has never turned on since!
__________________
fishinhardwater
  #18
Old March 25th, 2009, 09:09 PM
AEROCOOK's Avatar
AEROCOOK AEROCOOK is offline
Location: Innisfil Ontario on the shores of Lake Simcoe, ice fishing capital of the world.
Dont mean to hi-jack your post but there are 2 of you with the same motor as mine and I posted a while ago on a similar topic with little response.
My question to you is how long does it take for water to come out your tell tale after a hot restart? Mine seems to take around 5 seconds or so even after I replaced the impellor. Never heard an over heat alarm.
Just looking for a little reassurance that this is normal for these motors.
  #19
Old March 26th, 2009, 10:15 AM
i never timed it, but it does seems to take about the same (5 seconds, maybe even a little longer)
__________________
fishinhardwater
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Does a 1988 60 hp Mariner have a thermostat? RAZC60 Mercury & Mariner Outboards 11 June 10th, 2008 06:09 PM
1988 60 HP Mariner doesn't charge raporter Mercury & Mariner Outboards 4 May 14th, 2008 10:53 AM
60 hp Johnson-overheat alarm dead freetime99 Johnson & Evinrude Outboards 1 October 6th, 2007 10:56 AM
60 hp overheat alarm,frustrated buzzman 9403 Johnson & Evinrude Outboards 5 August 2nd, 2006 09:52 PM
Mariner 50 HP overheat alarm McGurk Mercury & Mariner Outboards 2 July 31st, 2002 09:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
