ilove2fixx
- Feb 13, 2016
- 501
Nope, it's not,.... What carb ya got,..??
The stock one im assuming its a mercruiser 3.0 2003 bayliner
well i came back and it wont shift onti first , after many attempts it will catch... but sometimes it revs high and catches and that impact is nasty..
Ayuh,.... That nut should be snug against the bushin' on the shaft,....
Ya gotta be lookin' at the shift cables,....
Disconnect the lower shift cable, 'n see if you can manually shift the drive into forward, 'n reverse,....
The lower shift cable is the one that goes from the shift plate on the engine to the drive.
Ok guys i tried manually shifting it and it does move the silver shift shaft by the spedomoter ?
Just drop it off at the dealer
If it was so simple why isn't it fixed. You need to follow the manual.Lol closest dealer is 30 min away and this is something simple we almost got it guys
I think its because people just read the first page and say "I can do this" and skip the next 10 pages not understanding how the steps must flow together
Lets slow down and get back to the basics. Somewhere in your post I put a link to the adjustments. With the drive in fwd and the shifter in fwd with no throttle
attach the black plastic sleeve to the bolt and then adjust the brass barrel to fit. Test operation and report back
