- Jul 18, 2011
- 17,712
Update:
Today, I brought the sailboat into the garage to 'lift' the top portion (deck and cockpit) off of the hull. This will give me good access to the hull and related structure to essentially rebuild the boat.
I tried to lift the 'cap' with straps and a chain hoist, but the straps were deforming the cap and damaging the fiberglass. So, I lifted the cap from the main bulkhead.
This was close to the balance point of the cap, but there was about a 50 lbs imbalance that needed support at the stern.
I slowly 'inched' the trailer and hull out from under the boat. At each movement of the boat, I supported the rear of the cap on the transom of the hull, since I had only a single lifting point.
After a countless number of small moves of the trailer, it was finally at the point where the cockpit sole was ready to clear the transom. At this point the cap and the hull would be free of each other.
Here is the hull (and trailer) pulled out from under the cap.
Here is the cap supported by the chain hoist and a couple of stabilizing lines
here is a picture of the hull. I can now remove/replace the old/wet foam that is in the aft berth chambers and do some other restoration work on the hull. I will also do some work on the cap
I will work the cap in the garage, but probably will have to work on the hull outside . . . somewhere.
