4.3 elbo gasket, restriction hole or not
onebighead
I have been working on a mercruiser 4.3 v6, no serial number, but a 1995 model boat. I am replacing the gasket between exhaust manifold and riser. The local shops only have the gasket that allows full flow. The gasket removed has the restriction holes. Could I use either gasket type? thanks in advance
Fun Times
It's best to wait and get the correct gaskets (restricted) as you'll be switching from warm to cold manifolds. Also on your exhaust system, the full flow gasket is used when you have an exhaust riser. It's normally placed between the riser and elbow. Item #'s 13 & 16, http://www.mercruiserparts.com/Show...r=11&bdesc=EXHAUST+MANIFOLD+AND+EXHAUST+RISER
< You need item # 5.
More helpful hints of what you need and why,
http://www.boatfix.com/merc/Bullet/99/99_10.pdf
https://www.perfprotech.com/blog/articles/marine-exhaust-tips
https://www.perfprotech.com/blog/tech-articles/warm-manifold-cooling-tips
Volphin
The proper Merc parts will have the restrictions built in. They are also thicker than aftermarket so they seal better.
Ayuh,.... 'n they're of a carbon metallic graphite material, rather than paper,... No doubt the Best I've found,...
