sailors hornpipe
- Apr 21, 2010
- 53
let me start by saying that im new to boating and have been out twice in 1992 180 nitro fs with a 150 hp johnston evinrude out board -i have owned it for 2 months- each tirp ive been on i was with a friend who is a boat mechanic - he is pretty much retired as he is now working at the hospital and says that at 60 he is to old to be working in the heat and tight spaces -i can only imagine-i do not question him as he is the expert but the more i read here-i start to doubt some of his ideas - for example we have had trouble starting the motor and he used ether both times to get it started- but i have read on this site many times to never use ether! if so why not and what should i use? both times we went out he started the motor and after some maintenance -he gave me the ok to strike out on my own next time- well i got out there today by myself with wife and backed down the ramp - i turned the the key and primed it at the ignition while it was turning over - now he told me to turn the key and not to stop priming until it started about( prime about 10 times) i did this and then remembered i had not squeezed the primer bulb so i did that until it was hard- then reapeated the process 2 more times - still the motor was turning over well- but would not start and i had it in high neutral as instructed -i removed the cowling from the motor and turned the manual primer a couple of times but same result! now both times we have been out the motor was difficult to start but once it was running and was shut off - it would crank up on the first try and purred like a kitten - it is the initial start that is very difficult - he came out to where i was and removed the spark plugs and said these plugs are wet and that means you flooded the motor-he left the plugs out and and told me to buy new ones as these were very black inside and we dont know how long they have been in there- he told me to leave the cowling off over night to help the engine dry out /charge the battery / and install new plugs in the morning- he is going to meet me in the morning at the lake to troubleshoot- 2 separate guys walked up while i was having all this trouble and both independently said " those evinrudes are very hard to get started !" one guy said he had one and sold it because of the same problem - is that true? now im sure that i did my part to screw things up but i cant have my friend go with me every time i go to the lake! one guy said not to choke it at all cause it is so hot outside 90 deg or more but my mech friend said to keep priming it until it starts? now my wife thinks im lying about the boat working good - i did buy a boat before- that i got burned on -it and it sat in my driveway for 5 years collecting dust 1978 caravelle it looked shiny and nice but turned out to be a piece of junk to far gone to fix up! so now my wife is laughing at me and telling me i got ripped off again! she wasnt with us the first 2 times - please help or ill have to sell the thing to stay married! what am i doing wrong? and how can i fix it??????????? please please help! i dont know about (sleepless in seattle) but im (fustrated in fort worth!)
