I recently just bought my first bass boat. 1985 Skeeter Starfire 150 with a mercury 150. serial # A114196. Had an alarm go off the first trip out. To make a long story short i replaced the temp sensor located below #1 cylinder, also installed a water pump and put thermostats in. still had an alarm go off any time i was on plane as soon as i back out of the throttle it quit. I noticed that it was still not peeing vary good at idle and low rpm. I checked the compression to see if there might be a head gasket problem. (as suggested by a mechanic.) The compression was 125psi to 130psi across the board. With no two having the same compression on the same side. The next thing i did was remove the thermostats and now it shoots a stream of water like 6ft.
My question is: Will running without thermostats cause a problem. and why do they even put thermostats on these motors. Might be a dumb question but i guess in my mind if there is no restriction than it will always be bringing fresh water through the motor to keep it cool.
