Have 1980 Evinrude 150 getting hot on port head while starboard stays fine. I have gone through the entire cooling system and have excellent water flow with everything working and operating at perfect temps with the exception of high RPM only port side head gets hot. Replaced the water pump, deflectors, t-stat, bypass valve, and cleaned some minor scale build up from the water passages. Also running the OEM Champion plugs for this motor. Running out of places to look. Could this be a carb problem? Perhaps partially clogged high speed jets causing it to run lean on one side? Any suggestions?
