I've noticed every time someone asks "can I tow this boat with this car" people always chime in about needing a truck, not a car. The reasons are varied, but none make any sense.
Some common things said are:
1. The car is not heavy enough to stop the boat/trailer in an emergency.
Really? So a 3500 lb car towing a 2000 lb trailer/boat is dangerous, but a 7000 lb truck towing a 12,000 lb boat/trailer is safe? How about a 15,000lb semi towing 80,000 lbs? Why the double standard?
2. The car does not have big enough brakes.
Again, really? The typical 3500lb sedan has 4 wheels disk brakes with 12.5 inch rotors. Trucks typically have 13.5 inch rotors, but weigh twice as much as the car does. Just look at the braking distances of cars vs trucks.
3. The unibody will get all bent out of shape.
I've read numerous posts about hitches failing on trucks. A simple Google search brings up millions of hits. Can't say I have ever heard of a unibody failing.
4. Buy a beater truck, it is safer.
So it is safer to use an old truck with 11 inch front rotors and rear drum brakes with no abs over a new car with 12.5 inch rotors? Why?
