I have been searching through older posts but can't seem to find
a problem similar to what I am experiencing with my 115 V4 SLEDR.
I was out in my boat over the weekend and while heading back to shore
the engine started losing power, it kept running but the speed dropped
to 8 mph at full throttle, I shut everything down and waited a min or two and then tried again with the same results I also tried squizzing the primer bulb, but there was no change in the running results. There were no alarms the engine temp was normal and no abnormal sounds or smoke was coming from the engine. I could take the motor out of gear and it would idle up just fine with no load.
Recently the Carbs were rebuilt the VRO has
been disabled (I am using a 50:1 fuel ratio) and the spark plugs have replaced. I am still using the orginal VRO pump to pump the fuel.
Could my VRO pump be failing?
