any thoughts on a front wheel drive minivan pulling a 21 ft Bayliner, approx 3000 lbs. ?
Have always used an SUV, considering a pickup, but concerned about wheel spin. Will be towing roughly 7000 lbs. Do you pickup users have this problem on steep ramps? Thanks.
7k isn't a small task 4x4 would be a must for me.. I don't want my ability to launch at any ramp hindered by my vehicle..
a lot of vehicles you can put in manual second to prevent wheel slip
Regardless where you are, if you intend to tow with a two wheel drive pickup or car, it had better have a limited slip or locking differential. Otherwise the only time you have two wheel drive is when both wheels have exactly the same amount of traction. When one is less than the other you are stuck..
Four wheel drive is over rated. I had 4x4's my whole life and now I went with a 2wd silverado 1500. Even in CT winters, I was using my 4x4 maybe 3 times a year. The amount of times I would use it, never made the increased cost, and maintainence worth it to me. More cost for the vehicle, less gas mileage... BUT if you went 2wd, a GOOD limited slip or automatic rear locker(like me) is a must for the steep launched. Also, dont get cheepo tires, that will not help. I routinely tow my boat to the launch, and its pretty steep there. no issues.
