longshanks
- Jun 12, 2006
- 188
I have posted a number of times here, regarding the performance of my 2006 four-stroke 50HP Mercury. I just bought the motor as a lease-return, it has around 30 hours on it now, and although there were some major issues with the power head, Mercury warrantied a new power head, which was rebuilt by a local Merc. mechanic. Motor is under warranty until June '08, which is a darn good thing, considering the number of times I've had to have it back to the mechanic so far.
I have now had it on the water about ten times, and I'm simply not getting the performance I think I should get out of it. My latest step was installing a tach, to see where abouts I am sitting with RPMs. I am looking for opinions on what I should do next.
I am spinning a composite prop on the boat, an 11 pitch by 12" diameter, and getting 4500 RPMs at WoT, moving a top speed of 23mph. It takes around 10-20 (or more) seconds to plane, depending on load. My mechanic recommended a lower-pitched prop, so I tried a 12.25 by 9", and it won't come out of the water, spinning only 3800 RPMs. Mechanic has inspected the motor, and feels that all is working correctly.
Now it seems to me that this motor is either set up incorrectly, or there is something wrong with the motor, or it is vastly underpowered for my hull (15'). I'm guessing the weight of the hull alone to be around 1000-1200lbs.
I was hoping for an improvement in performance when I bought this motor. I also have a 2-stroke Mercury 45 jet motor, which I get out of the hole in 6 seconds with, and run around 28mph. Tests that I have seen online for 50 horse 4-stroke motors show top speeds of around 28-30mph, at around 5800 RPM, give or take. I'm nowhere near these figures, so I thought I'd post a couple of shots of my rig, and see if you guys have any thoughts what is wrong?
cheers
longshanks
cheers
longshanks
