Re: WHy don't people buy Proper Tow Vehicles?
Most of the places where I launch it's saltwater and pretty slick and shallow. I try to use the cheapest tow vehicle I can find since they tend to rust away in a few seasons anyhow. Ever have a quarter panel rust off at about 70 mph and slide down the road?
The best one was an old Dodge that I gave $150 for, it was a '79 with a 318 engine that needed a trans seal, the bed was decent when I got it but after a few rounds with saltwater it's days were numbered, the right quarter panel fell off heading down the highway one day and after a few years I had to bolt one door shut after the latch area rusted away. We had cut away a hole in the hood so we didn't have to fight with the rusty hinges to add oil and brake fluid, so it looked a bit rough.
The worst part was the roof rust, there was a 2" band all around the top that had rusted out, when it rained you needed goggles to see. When we first used it to launch a boat it spun and slid all over, the next time out we made sure we welded the rear spider gears solid, after that it did just fine, never spun a tire again. I had a set of Hercules All Terrains in the back and stock tires up front, the added height in the rear helped level the trailer which was hitched to a homemade rear bumper/hitch. If it needed some more height, we just pumped up the rear air shocks and air bag helpers.
After the bed fell off we just made a makeshift bed out of 4x4's and plywood, it actually made launching easier since one guy could stand on the rear deck and jump in as it floated. The boat back then was an old Renken 23' fishing boat. The home made flat bed also worked better for hauling bait and such, it was easier to load and didn't get slippery when it got wet or covered with bait. The rear window went away in the last season we used it, someone left a sinker on a rod which was leaning against the back window and on a hard bump, the glass was gone. While it let water in, it didn't matter much with the rusted out roof. It also ended any chance of getting locked out of the truck since we never did have the right door keys. The ignition switch was a doorbell button and the key was only there to unlock the steering.
I finally sold it after the frame started to rust, some farmer is probably still running that truck. It ran like a champ, but looked a bit rough. The worst part I ever thought about that truck was that the drivers back of the seat was broken, you had to prop a milk crate up behind the seat so you could lean back.
It got a lot of strange looks but it never got stolen, never got broken into, and never failed us. Best of all I never worried about it, if something ever happened to it, the most I ever would have been out was the value of the tank of gas, which back then was about $20. The best part was when someone new decided to go along with us, the ride down in that old truck used to really shake up some people, especially when the heard the brakes sliding at every stop or saw me using the parking brake to get the rear brakes to work a little better. All in all we had that truck the longest, I had replaced it with an older 4x4 that never had the power like that one did and being a regular cab, there was no room inside for any gear. That one only lasted about a season before I got tired of trying to keep it running.
