Re: Boat won't get up on the pad
Dhadley,<br /><br /> The number on the prop is 5477. Are you guessing that has been reworked because of the age, or do you know some secret that I am not aware of. I know the previous owner and if was reworked, he was not aware of it. I have the motor 1 notch shy of being as high as I can go without a jack plate. What set back should I shoot for? Any suggestions on brand? I have a rotary teleflex steering system. I appears to have minimal torque (easy to steer) once I am on a plane. What is the Max RPM range that I should be running in? The stamp on the side of the motor says 45-5500 is the target range with 5K being the point where max horsepower is achieved. It is an old motor and it does not appear that it has been rebuilt, so I am a little scared to run it past the target range. Not saying that I would'nt, just not very comfortable with the idea of blowing it. I don't know whether I will need to replace the steering cables if I put a jack plate on. I have some length available. The appear to be fine, so I hate to replace them if I don't need to. Thanks for all of the information. I will raise the motor to the highest hole and let you know what happens. 65 would be outstanding. If you think it will do that I will try any suggestions that you have to get it there. <br /><br />Thanks
