I have a '94 Yamaha 25 hp single carb 2 stroke engine. It's stored away from a water supply so I want to completely drain the carburetor of fuel for the winter. I've attached a photo. Is the bright brass screw with the spring the drain? I was afraid to fool with since it looked like an adjustment screw.
IF it is a drain, is just backed out enough to drain, or what?
