Aar0n
- Mar 24, 2016
- 24
Noobie here. I just bought my first boat, a used--but new to me --2008 Four Winns Horizon 180 from a local dealership. The boat is in excellent condition—nice and clean, including the motor, bilge, etc. Being in Utah and with winter just starting to loosen its grip, I haven’t even had it out of the garage yet. The boat has a Volvo Penta 4.3 GL-J and SX-A outdrive (I can provide more info if it's needed, I'm just not sure what exactly more might be needed).
Well, I finished reading the Volvo Penta owner’s manual about a week and just got around to checking all the fluids and walking through the other routine maintenance checks. The only thing that seemed amiss was the fact that the power steering reservoir was a little low—about a half an inch below the minimum marker. I got to thinking about it and came to the conclusion that there must be a leak somewhere, otherwise, why else would it be low? I checked the hoses and related connections running from the reservoir to the pump: clean. The pump itself: clean. The hose running from the pump to the actuator and related connections: clean. The return line to the cooler, the cooler itself and related connections: clean. The return line running from the cooler to the reservoir and connections: clean.
Then I checked actuator more thoroughly, including the cylinder on the left side near where the hoses connect. Sure enough, after running my fingers on the underside right where the cylinder goes into the housing, they came up with oil on them. So, I know where my leak is. Just to give you a better idea of where I'm talking about, this post by ThreeMileBayWaker here on iboats has images of what appears to be the same actuator I have with a leak in the same area as mine: http://forums.iboats.com/forum/engin...mal-pic-inside.
Interestingly enough, there is no oil residue on my hull underneath the area where the leak is at, nor anywhere else in the bilge. And it’s not like someone wiped it up to try to hide it, because there’s a layer of dust right under there that also would have been cleaned up had they done a wipe down. I find that a little baffling.
Anyways, I plan to try the repair myself.
I should mention that I’'m certainly no mechanic, but I’'m not exactly a stranger to getting my hands dirty, either--—I’'ve owned multiple Jeeps that I’'ve maintained and “built up” myself (e.g. suspension, steering some body work, axles and some driveline repair).
I found the following write-up, if you can call it that, on the removal and replacement:
http://www.justanswer.com/boat/86q14...-cylinder.html
I plan to use it as my main guide.
OK, here are the specific questions I’d be thrilled if you much more experienced folks than me would consider kindly helping me out with:
- Do you have any advice/tips/pointers/things to be mindful about the removal and installation of the actuator that you can share?
- Does the system need to be bled, like you would with a car braking system? If so, how would one go about doing that?
- Is this the correct part number: 21910902?
- This thing is pricey! My local authorized Four Winns dealer quoted me $750 for just the part. I found it online for about $620 with free shipping. Do any of you have any hot tips on where I can perhaps pick one up for less?
- I know the actuator isn'’t supposed to be serviceable, but I found this write-up here on iboats that intrigues me and there are a few hydraulics shops near me: http://forums.iboats.com/forum/engin...a-steering-ram. Have any of you others ever heard of this being done? Would you recommend taking the whole actuator into a local shop and seeing of they’ll give it a shot? Daleg70, if you’'re still around here on the forum and happen to see this, maybe you might share how it’'s worked out for you long term.
Thank you very much in advance for any insight or opinions you can offer a recovering landlubber.
