How do I add a oil pressure switch to it?
Can I use an oil pressure switch from a auto parts store?
Short answer: YESCan I use an oil pressure switch from a auto parts store?
Short answer: YES
Much longer answer:
There's a number of ways to do this. I would use a relay to run the fuel pump and let the oil pressure switch ground the relay. I'd also have a start relay that was wired in, but only is energized by the start circuit. A bit more wiring and expense, but better electrical distribution and, in my humble opinion, elegant. If interested, I can help you with the wiring.
Oil pressure switch standard parts# PS133T
2X 30 Amp Relay dorman part # 84601
That switch can be used to wire the fuel pump w/o a relay as stated in previous the posts. (This is the reason for the bold)The middle post would be to light a warning light, the two that are parallel to each other complete a circuit when oil pressure is 7lbs or higher.
The plumbing (T and what have you) are up to you, but dodge trucks of the mid 80s have a piece that has two ports on it and would screw into the brand X block you have and save some space & money and allow you to still use your factory oil pressure switch. I imagine that most Pick & Pull JY would basically give you the piece.
Good luck.
sb
One more question. What size wire should I use for all of this?
