Hi Guys, first post here, but searched a fair bit and lurked here also before posting!
My boat threw a belt, stripped one edge off so I got a belt and tried it, the belt is walking forward one groove on the bottom of the crank pulley, this obviously caused it to strip the last belt eventually. I hand spun and checked the alternator, power steering and tensioner pulley, all spin true and smoothly. The waterpump pulley has play side to side, I assume it should be smooth like all the others, it feels like its bearing is dead. It will spin but its obviously not going to be smooth. Also when I initialy popped teh belt on tand run it it made some pretty hideous clanking sounds that seemed to time with the belt jumping forward a groove.
All the brackets appear fine on the ancillaries so I think its just the waterpump. I have ordered a new one from my local Mercruiser agent. Now for the questions...
1) Should I change anything else? (they gave me a power steering puley with belt, its a pain to change, I can't see any reason too? Why did they supply it in the kit?
2) Would a busted pump bearing make a horrible sound and would it cause the belt to jump forward?
3) Any advise on anything else to check (it just had a service)
Anything else?
Thanks for your help in advance guys! Here is a pic. I will be cleaning up the rust on the pulleys before taking her out again.
Tom
Anything else?
Tom
