Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
84 Merc 260 shift cable. whats that part and how do I replace
  • 84 Merc 260 shift cable. whats that part and how do I replace
    Underneath the top section of my Alpha outdrive there is a metal tube that connects the shift cable to a threaded pin in the lower housing. I rotated the pin and it switches the unit from forward to reverse. When I push up no the tube one would expect it to connect to the shift cable, in my case if you find the "right" position rotating it .. it will connect otherwise if just spins freely. If I get it in the position where it connects how do I keep it there while installing the lower unit ? If not possible how do I replace the cable ? Can't find the R/R for this anywhere. Do I have to remove the upper half of the
    outdrive ? I went to West Marine and we found the correct shift cable but it doesn't look anything like what I am looking at under this upper-unit. No tube. no washer with cotter pin on the tube.
    Thanks
    OTG
    Re: 84 Merc 260 shift cable. whats that part and how do I replace
    Is this what you are looking at?
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Haven't dug that deep yet. Here are two pictures of the parts. The tube hanging from the upper slides over the pin (gold ring on left of pic). Finally found my camera.
      OTG
      • #4
        there should be a stainless steel washer that goes on the shaft first, then install the lower
        NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
        • #5
          Did that. Problem is when the "tube" is pushed upwards it does not always attach to the
          shift cable. Have to rotate the metal tube and push upwards before it eventually connects.
          Thinking the cable end is messed up.
          Thanks
          OTG
          • #6
            That is your intermediate shift shaft. It does not attach directly to the shift cable, it slides into the coupler on the bottom of the upper shift shaft, which does "attach" to the cable. This is a illustration of the parts :http://www.mercruiserparts.com/Show_...c=BELL+HOUSING 23 is the shaft, 21 is the upper ss. It works this way: When you move your control handle the shift cable moves back and forth (back for F) and moves an arm attached to the upper ss. This rotates the ss (cw for F) and the rotation is transferred to the intermediate ss in the driveshaft housing and on to the lower ss in the gear housing. That movement slides the shift spool back and forth to engage either F N or R. The coupler at the bottom of the upper ss allows the two shafts to slide apart when you remove the entire drive. This is what you need to do: Shift the control handle to forward WOT. Turn the short splined shaft (lower ss) all the way clockwise, make sure the stainless steel washer is in place on top of the lower ss bushing (brass in photo), rotate the prop CCW until it locks and bungee it in place (you are now locked in F). Make sure the quad ring is in place in the oil passage, and slide the gear housing up into the driveshaft housing, making sure the top of the intermediate ss is pointed straight ahead when it slides over the lower ss, so that it matches the coupler on the upper ss. If you have to rotate the prop to get the driveshaft splines to slide in, rotate CCW only. Should fit in there quite nicely. Good luck.
            Terry
            87, 4WINNS H 190
            470/Alpha I
            • #7
              This is where I messed up. I was thinking the top of the intermediate SS was internally splined like the bottom. This is why it only "connected" at certain rotated positions.
              Have to read it again and look up into the cavity to see what pointed straight ahead means. The parts breakdown shows it as being pretty obvious.
              Thanks so much for the information. Wasn't looking forward to replacing the cable especially when it isn't necessary.
              Thanks again
              OTG
              • #8
                Look at Ziggy's photo. That is NOT straight ahead LOL. If it were rotated 1 click to the left it would be.
                Terry
                87, 4WINNS H 190
                470/Alpha I
                • #9
                  Finally found the parts shown in Don's picture. That's exactly how it looks from a weird angle I might add. That is definitely where I screwed up originally. I set the shift linkage to get the two pieces facing straight forward but could only get it the way Ziggy's picture has it, one click off. There is no more adjustment in the cable for a true
                  straight ahead so I am going to try it this way after getting some replacement gaskets.
                  There is an adjustment tool that they sell for this shift linkage ? Do I need it ?
                  Thanks
                  OTG
                  • #10
                    Well I got the pump rebuilt and now I am setting connecting the upper/lower units. My shift shaft looks exactly like ziggys above (one click off to the right). I disconnected the cable at the engine and it is bottomed out. Translation I can not get the cable to point straight back to match the intermediate shaft. Tried to move the shift the intermediate shaft over one notch on the pin but it will not slide together.
                    How do I get them to align ?
                    Thanks
                    OTG
                    • #11
                      You need to rotate the intermediate ss all the way clockwise. Turn the prop ccw until it locks. Pull the intermediate ss up off of the splined lower ss, and rotate it clockwise so that it points straight ahead and push it back onto the lower ss. Make sure the control handle is WOT forward and the connection on the bottom of the upper ss is pointing straight ahead. She should go together.
                      Terry
                      87, 4WINNS H 190
                      470/Alpha I
                      • #12
                        I have the lower ss straight ahead and the unit is locked in forward. Have a bungee holding the propeller. the problem is the top "female receiver" is one notch to the right like in the picture and I can not get it to point straight back to match the lower SS.
                        Am I misunderstanding something ?
                        Thanks
                        OTG
                        • #13
                          The control handle is all the way forward?
                          Terry
                          87, 4WINNS H 190
                          470/Alpha I
                          • #14
                            Yes even disconnected the cables from the engine linkage and moved the adjustments to the stops and I still cant force the recepticle straight forward.
                            • #15
                              Did you push the cable or pull it? You have to push to go into forward.
                              Terry
                              87, 4WINNS H 190
                              470/Alpha I
