So I am at a pivotal point of the construction and would value the communities opinion on a few things before I proceed. Help me Obi Wan, your my only hope :laser:.
First order of business that I need help to decide on, though I feel it is always a great idea to follow the original layout of the structure as the oem intended, it seems this Evinrude was a little different in how other company's designed their transom and deck. Just about everything I have seen in these forums or on youtube for other boat designs has the transom extending all the way to the bottom of the hull and secured to that point. Then the decking is fit next to the transom and attached. When I dismantled the "
Rude Awakening", it was just the opposite. The decking was secured down all the way to the keel and thus the transom was mounted on top of the decking, tabbed in of course. My intentions from the very start was to follow this plan and rebuild as it was by the factory.
I guess my question is that I intend on following that setup, would there be adverse issues doing it this way?
Second order of business that needs to be addressed is concerning remounting the removed splash-well top. As you can see in this picture, she lines up perfectly and thus no hull spreadage, which is a godsend:
I was pleasantly surprised and happy to see this, but with the width of my current design of the transom, 1 1/2" plus matting, I am thicker than what will fit:
What would be the best way to remedy this? I would like to keep my original plan of double 3/4" marine ply plus the 2 x 6 cross-member. (2 x 6 is not an issue atm but I do have a question about that as well when the time comes). Since I am about 3/8" shy of needed room, my thoughts were to remove that 3/8" from the front of the splash-well before reattachment and just extend the lip on the keel edge to make up:
