kcon
- Dec 10, 2016
- 302
Howdy!
So I got a 1980's 17' "Hyrdo-Glass" bow rider outboard, with fully operational late 1980's 2-stroke 90HP Mariner outboard, for $2,000. First boat I've ever owned and turned out to be WELL worth the $2,000, used it all summer long on the Hudson River in NY with very little issue (Fortunately I worked for Sea-Tow for a bit as a contracted software developer so I had the free membership ready to go just in case) the boat does about 40MPH conditions permitting. Anyway the boat didn't look too pretty, as fun as it is, so I decided to go into a full restoration blind, despite many boat mechanic friends saying it's a waste.
Here it is in it's glory
The plan was to replace the deck, patch up cosmetic fiberglass spots, fresh paint, new carpet and seats, etc. however after exposing beneath the (rotten) deck I found poorly glassed rotten stringers, and turned out the transom was 100% rotten, I don't know how the outboard didn't fall off at this point, cause I pushed the boat hard all summer long. Here's some progress pictures of where I'm at so far. Unfortunately it's mid December in NY so it's tough to handle glassing anything out, or even working outside... but my goal here is to finish this by June 2017 to get back out on the water.
Exposing the rotten transom...
So that's where I'm at, I'll post updates as I progress. Unfortunately the amount of prep work inside the hull to smooth it out and prep for new stringers / fresh fiberglass is boring and difficult, but I dredge on! I had to get between some layers of structural fiberglass to pry off the transom, so shown above I used some sheets of CSM and 105 epoxy resin to level out the transom area so I can smooth it and apply 3 layers of 1708 for structure, followed by the new transom. I'm gonna have the motors carbs rebuilt and probably get a new prop, that is if I decide to keep the motor instead of just getting a new one...the thing ain't great on gas, but being a pre-mix 2-stroke it runs all day long.
Anyway, thanks for reading! If you have any tips or pointers based on what you've seen above I'm always welcome to criticism!
